Does a zigbee series 2 ( xbee ) module have a inbuilt microcontroller? If yes, is it possible to reprogram that microcontroller? If not, then is it possible to use an external microcontroller.
  • \$\begingroup\$ I don't know the particulars, or exactly what you are talking about, but the TI chips that I have looked at, and are the heart of most hobbyist zigbee modules, have a 8051 ip core that you would program over jtag \$\endgroup\$ Commented Mar 7, 2013 at 4:58
  • \$\begingroup\$ why is that , I am getting negative comments ? \$\endgroup\$
    – hanu
    Commented Mar 7, 2013 at 8:36
  • \$\begingroup\$ @hanumesh - I don't know why you are getting downvoted. It seems like a reasonable question. \$\endgroup\$ Commented Mar 7, 2013 at 11:33
  • \$\begingroup\$ how to communicate between xbee S2 and microcontroller without using any software???, (I just want to use my xbee s2,hyperterminal and controller) pls reply me asap… \$\endgroup\$
    – user20498
    Commented Mar 21, 2013 at 10:12
  • \$\begingroup\$ @Prasad if you have a question, please click on the button "Ask question" in the top right corner. For the best results, please write it as clear and complete as possible. \$\endgroup\$
    – clabacchio
    Commented Mar 21, 2013 at 10:16
The XBee devices do have built-in microcontrollers.
However, Digi does not make a SDK, or the resources required to compile your own firmware image available for the Series-2 XBees.
You could probably theoretically reverse-engineer the modules, and write your own firmware for them. However, judging from the fact that you're asking this question, I think that's a bit over your head at the moment.
  • \$\begingroup\$ @thank you !!. I have a two working xbee series 2 modules, one i have set-up as co-ordinator and other as end device using x-CTU tool . Now , i have to connect a sensor to one of the xbee module and transmitt data via zigbee n/w and show the transmission . \$\endgroup\$
    – hanu
    Commented Mar 7, 2013 at 5:57
  • \$\begingroup\$ Unless your sensor has an analog output (and you're willing to live with the crap 10-bit resolution of the XBee ADCs), it sounds like you'll need an additional MCU at each end. \$\endgroup\$ Commented Mar 7, 2013 at 5:59
  • \$\begingroup\$ 1 )answers.oreilly.com/uploads/monthly_02_2011/… \$\endgroup\$
    – hanu
    Commented Mar 7, 2013 at 6:06
  • \$\begingroup\$ 2) answers.oreilly.com/topic/… \$\endgroup\$
    – hanu
    Commented Mar 7, 2013 at 6:07
  • \$\begingroup\$ these two links say that it has analog inputs? I am i right \$\endgroup\$
    – hanu
