What I am looking for is some open driver that tackles more than just 48 kHz.
Or a trick, if there is one.
PIN30 MCLK gets 24.576 MHz and I have internal counters to count down with, for the speed of the I2S.
As shown in the datasheet, the CS43L21 does not automatically support 8 kHz sampling rate with 24.576 MHz MCLK.
Either halve the MCLK output from the PLL, or enable MCLK dividing by 2 at the DAC in hardware or software, or disable auto-detection and set the MCLK to FS ratio manually.
