I have purchased an RTX 2080 which contains a scorched component. I have carefully removed it with a heat station. The card is not short and it works, but it is seen with artifacts.
As I found on the internet, I believe this is a ferrite bead or an EMI filter. I went ahead and measured the size of the component and I think it measured between 2mm x 1mm and 1.6mm x 1mm.
Do you think that not filtering of the electromagnetic interference is causing the artifacts or the problem is from another component (maybe the RAM)? Also, can I solder a ferrite bead of similar characteristics (a ferrite bead of the same size) or does it have to be the exact one to not mess with the circuit? I am not really certain on how ferrite beads and EMI components work
