Is it possible to add a variable into the value of a component in LT spice? I'd like to simulate a resistor divider to look at current consumption but keep the ratio of the resistances the same.
I tried setting R1 to {X} and R2 to {X*1.5} but couldn't get it to work correctly. Haven't found the solution on Google and haven't been able to successfully run it. Maybe I need to define X somewhere.
