I want to connect Nexys 4 DDR FPGA board to a circuit on a breadboard (using pins on the "PMOD header"), but I am a bit worried about accidentally damaging the FPGA: like, for example, by connecting output pin to another output and causing short.
The reference manual doesn't say much about those general-purpose pin headers, but from the schematic of the board, it seems there is a 200ohm resistor on each pin. I suppose these are there exactly to protect the FPGA in such a case. Would it survive connecting a low-output to 3.3V?
What is the configuration of those GPIO when they are unused (no port attached to them in constraints file); are they input by default?
And what about when the board is programed by the default (snake on display and colorful lights) code? This will get loaded after each powerup before programing with my code, are the Pmod pins inputs in this case? They seemed to me as tied low when tried to measure them.
    \$\begingroup\$ the datasheet should have the info about the poweron state of the pins \$\endgroup\$
    – jsotola
    Dec 21, 2021 at 17:55
I'll assume that means "in series". (check, please. If it's just parallel to ground, then this offers no protection.)
200 Ω: protects, a bit, but probably more because you'd want to have some termination on a high-speed line.
You'll need to read the FPGA's datasheet. The "maximum ratings"/ electrical characteristics will tell you how much current is OK to sink.
The worst-case current sunk into a low output through 200 Ω from a 3.3V input is (3.3 V - 0V) / 200Ω = 16.5 mA. That might well damage a more sensitive pin, but the FPGA's outputs that are used for the PMOD header might well be capable of withstanding that. Or they might not. Datasheet!
Honestly, if you're so worried, then simply don't make a mistake (this sounds ultra stupid, I know); design the interface to the PMOD once, carefully, build it without the FPGA in place, solder it together instead of keeping it on a solderless breadboard. Not like you need a lot of flexibility on that side of things: the whole point of FPGAs is that it's easy to reconfigure them, so you can externally define once "this is going to be low-speed input," and so on, and add protective measures as adequate.
Ah, that will be part of what's written in the data sheet. Possible, but unlikely, that things are pulled down strongly before reset. (unless your external 200Ω are actually pull-down resistors and not in series) Might be a weak internal pull-down. Anyway, pre-configured state is super important for FPGA applications, so definitely something that's well-documented.
  • \$\begingroup\$ yes, the resistors are in series. By some experimenting I determined that in the default code (which gets loaded after powerup before uploading my project), the pin will draw about 0.1 mA when connected to 3.3V, which fits in IRPD Pad pull-down parameter from datasheet, so it is probably in this mode. \$\endgroup\$ Dec 22, 2021 at 16:43
