I can make "normal" footprints at ease in Altium manually or with the wizard but when it comes to abnormal footprints such as this inductor I have no idea how to go about making it and no library I have found already has the footprint premade:
https://www.digikey.com/en/products/detail/coilcraft/LPS4018-472MRC/12714478?s=N4IgTCBcDaIDIAUDKAWADARgBwFoUHYIBdAXyA
I suppose I could draw lines and calculate all the coordinates they are supposed to be at and fill inside the lines as the pad but that seems like a pretty tough way to do it. The easier way for me to make it is to use a CAD program like SOLIDWORKS or OnShape and draw it and extrude the shape I want. The way they dimension the footprint makes it much easier to make using one of those programs but I'd love to know if there's an easier way. If there is a way to export the file from Solidworks or Onshape, not sure what file type of how to import it. Everything I've found online suggests CAD importing is for 3D models not footprints. Here's the footprint I designed on OnShape and extruded 1mm:
