I have a simple Christmas light LED pack. It features 3xAAA battery compartment, an on off switch, a 10 ohm resistor in series and 9 white LEDs wired in parallel along about an 80cm two wire lead.
Obviously with just the 10ohm resistor, the batteries do not last terribly long. So I thought I would replace the 10ohm resistor with a 150ohm resistor. When I bridge the 150 ohm resistor across the open switch and 10 ohm resistor (i.e. connect +V to the 150ohm resistor then to the LED which in turn connects to -V) I observed a current draw that I did not expect.
The current draw that I observed was about ~9mA which was quite different from what I calculated ~30mA.
I have used two multimeters and obtained very similar measurements. Following is the original circuit and the modification I used to measure the current.
Here are my readings using two different multimeters.
Measurement | Multimeter 1 | Multimeter 2 | Units |
Voltage (+ve terminal to -ve terminal) | 4.05 | 4.03 | Volts |
Resistance | 148.8 | 149.4 | ohms |
Current | 9.43 | 8.9 | mA |
However, using the formula V = IR or reworked I = V/R. I would have expected that I should be 4 / 150 = 0.0267 mA or 27mA, not the ~9mA I measured.
The resistor I used has the following bands: Brown, green, black, black, brown. And the 3 AAA batteries have been powering the LED's for probably 3-4 hours already via the 10 ohm resistor hence the voltage of about 4V remaining.
So my question is why is my calculation so different from the observation by a factor of about 3x? What am I missing / doing wrong?
