6
As the title says: Is it possible to add automatically not installed libraries in Altium ?
After I reinstall Altium all the libraries I have added are not there I have to add them one by one again looking through every component I have.
Is any way to force Altium to analyze Library directory and search for missing libraries in my project?
Two solutions:
1. Search Path
Add your library path to the system search path. It will look there to find any missing libraries.
To do this, use the "Available Libraries" dialog and select the "Search Path" tab. Add your path to the list.
2. Install Libraries Globally
Install your libraries at the system level then all your libraries will be available in all of your projects.
To do this use the "Available Libraries" dialog, "Installed" tab (you'll have to switch as it is not the default tab when the dialog opens and it looks identical to the "Project" tab layout).
Click the "Install" button and shift-select all of your libraries.
  • \$\begingroup\$ Having them in different folders, as ussualy one gets store them, make this to select each file individually...?? Thanks in advance... \$\endgroup\$
    – Brethlosze
    Apr 16, 2018 at 17:16
    \$\begingroup\$ Besides, when i go to the dialog Search Path options, it only seeks me *.PcbLib files, and not *.IntLib files... do you know why that happens? \$\endgroup\$
    – Brethlosze
    Apr 16, 2018 at 17:23
  • \$\begingroup\$ @hyprfrcb -- You can add folders in the "Search Path" tab. The "Project" and "Installed" tabs require specific individual files, but you can use shift-select in the "Install" dialog to install many individual files at once. You can change the type from "PcbLib" to "IntLib" in the "Install" Dialog using a filter box in the lower right corner (IIRC). \$\endgroup\$ Apr 18, 2018 at 19:47
  • \$\begingroup\$ How does one locate the "Available Libraries" dialog? \$\endgroup\$
    – brainfog
    Aug 28, 2018 at 17:37
