Suppose we have a linear voltage regulator:
If Vin is above Vth Vout is costant for all values Vin may take.However if Vin is below Vth what is the relationship between Vin and Vout?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communitySuppose we have a linear voltage regulator:
It depends on the internal circuitry of the regulator. If the manufacturer doesn't provide this information then you should not make any assumptions, except that the regulator no longer regulates. One thing you can be sure of is that \$V_{out} \le V_{in}\$
You have to rely on the data sheet. Some manufacturers provide schematics, but none of them claim that they are good for analyzing performance outside of recommended operating conditions: they're just to aid understanding how the part works. If you find a part that does have detailed performance data you can't depend on another part, from someone else, with the same generic number (like 7805) performing the same. If you test a part and find it meets your needs beyond the published specifications, you can't even assume that other parts from the same manufacturer also will. A later production run can be lots different. The only thing that counts is the data sheet.
Short answer: it depends
Longer answer:
We have to consider dynamic cases and static cases. For example, when the input voltage suddenly drops (and if there is a high capacity on the output side or really low load) the output can be higher than the input. You'll have to refer to the datasheet of your regulator (make and model) to see what it can handle and when it will break (you might need a reverse diode to protect your regulator if the possibility of Vout > Vin exists).
For a case where \$V_{in} < V_{out} + V_{th}\$ you'll have to refer to the datasheet again. Keep in mind, that you can get parts with the same number from different manufacturers. The internals of an 7805 from one manufacturer do not have to be the same as the 7805 of another one. So different things can happen.
Generaly: don't run components for prolonged times outside specs. Wierd things can happen there.
