I have a source-synchronous input to my FPGA (an Intel Cyclone 10 GX 10CX085), coming from an external chip whose datasheet gives the following information:
- fmax = 300 MHz (single data rate)
- tsetup = 0.4 ns
- thold = 0.5 ns
Using an oscilloscope, I can see the data is "center-aligned" (such that the data values are stable near the rising edge of the clock).
I have stripped my whole design down to two flip-flops and I still struggle to meet timing, even if I heavily relax the timing constraints. The whole Quartus project can be downloaded from here.
By closely following Intel's free training course, I understand that for best timing performance I should instantiate a PLL (specifically, an IOPLL configured in "source synchronous" mode) and my timing constraints should be defined like this:
# Define input clock parameters
set period 3.333
set tsu 0.4
set th 0.5
# Define input delays
set half_period [expr $period/2]
set in_max_dly [expr $half_period - $tsu]
set in_min_dly [expr $th - $half_period]
# Create virtual launch clock
create_clock -name virtual_clock -period $period
# Create physical base clock (phase shifted by 180 degrees) on FPGA pin
create_clock -name Clk -period $period -waveform "$half_period $period" [get_ports Clk]
# Create generated clocks on the PLL outputs
derive_pll_clocks
# Set input delay constraints
set_input_delay -clock [get_clocks virtual_clock] -max $in_max_dly [get_ports InData*]
set_input_delay -clock [get_clocks virtual_clock] -min $in_min_dly [get_ports InData*]
This failed timing catastrophically, so I tried relaxing to a 10 MHz clock with an extremely generous thold = 25 ns:
set period 100
set tsu 0.4
set th 25
This also failed timing. However, if I manually adjust the phase of the PLL (to basically anything sufficiently larger than zero) then timing is of course met comfortably at 10 MHz:
This leaves me very confused about the following:
- Are my requirements (300 MHz, 0.5 ns, 0.4 ns) feasible with this device?
- If so, then how? (Timing contraints, PLL configuration, etc).
- If not, then what performance is possible? (I can't see this information anywhere in the FPGA documentation).
Many thanks in advance for any help!
in_max_dly
because it is a known quantity at capturing flop and is hence already incorporated by STA tool in the destination path. \$\endgroup\$DDIOINCELL_X38_Y14_N35
. As far as I understand, this is the dedicated IO register needed for good timing performance (by GPIO standards). I also tried explicitly settingFAST_INPUT_REGISTER
on the data pins in the .qsf file and it gave the same result. \$\endgroup\$
