I have the following Verilog modules, which I'm simulating with Icarus Verilog. It seems that the ternary operator doesn't work, or has a bug:
main module (i2c_app_tb.v)
`timescale 1ns/100ps
module i2c_app_tb;
    wire t1;
    wire [7:0] t2;
    reg rst = 0;
    reg clk = 0;
    pullup(t1);
    pullupdown_t1 pt1(t1, t2, rst, clk);
    always #5 clk <= ~clk;
    initial begin
        $dumpfile("i2c_app_tb.vcd");
        $dumpvars(1, i2c_app_tb);
            rst <= 1;
        #20 rst <= 0;
        #300;
        $finish;
    end
    wire _i0_reg;
    assign _i0_reg = pt1.i0_reg;
endmodule
pullupdown_t1.v
module pullupdown_t1 (
    inout wire i0,
    inout wire [7:0] i1,
    input rst,
    input clk
    reg i0_reg;
    always @ (posedge clk or posedge rst) begin
        if (rst) begin
            i0_reg <= 0;
        end else begin
            i0_reg <= (i0_reg == 0 ? (1'bz) : 0);
        end
    end
    assign i0 = i0_reg;
endmodule
When I simulate the above, I get:
However, if I replace
by
if (i0_reg == 0) begin
    i0_reg <= 1'bz;
end else begin
    i0_reg <= 0;
end
(which is equivalent), I get:
Am I missing something? Is this a bug?
  • \$\begingroup\$ Check the data types — not every type supports ‘z’ which is defined as not driven. Only a tri-state signal path can physically support the z state. \$\endgroup\$
    – MarkU
    Dec 30, 2021 at 22:26
If you want to use the ternary (conditional) operator, you can use case equality (===) instead of logical equality (==):
i0_reg <= (i0_reg === 0 ? (1'bz) : 0);
Refer to IEEE Std 1800-2017, section 11.4.5 Equality operators.
The behavior you observed is not a bug and it is not specific to iverilog; it is observed on other simulators as well.
In your original ternary code, when i0_reg has the value 1'bz, then the expression i0_reg == 0 evaluates to 1'bx, and i0_reg is assigned the value 1'bx.
