7
Is there a formula or a way to calculate Charge time of a capacitor given that it is charged by a current limiting power supply. This would lengthen the charge time but is there a way to calculate this due to the power supply limitations. Let's say that we are charging a 1uF Capacitor to 5,000VDC through 20kOhms of resistance in series.
    \$\begingroup\$ I realize it is just an example, but I'd be a tiny little bit careful when charging capacitors to 5kV on your work bench. Otherwise good question. \$\endgroup\$
    – jippie
    Mar 8, 2013 at 21:48
8
As it is not a piecewise continuous system, you'll need to calculate, in two steps:
First: you'll need to calculate the time of charging the capacitor until it reaches
$$ (Vb-Vc)/R = Imax $$
with constant current of Imax. if the current is constant that capacitance does not change this is a simple straight ramp curve upto the point where the current is no longer limited by the constant current.
Second: you can use the equations for power supply without limited current power supply.
Which are the exponential curves from that point onward to the asymptote.
  • \$\begingroup\$ This is not an answer. You should comment to my answer instead. \$\endgroup\$
    – user17592
    Mar 8, 2013 at 15:02
  • \$\begingroup\$ OK. My fault... but I can't comment yet. \$\endgroup\$ Mar 8, 2013 at 15:07
  • \$\begingroup\$ Jean this is a perfectly good answer, and you're welcome to create your own. \$\endgroup\$ Mar 8, 2013 at 15:21
  • \$\begingroup\$ @rawbrawb: Camil's complaint was about a comment I made to him (in my answer, since i could not comment others commentaries yet) that there was a current limitation, then Imax could not be Vb/R. I edited the answer then. \$\endgroup\$ Mar 8, 2013 at 15:25
  • \$\begingroup\$ @JeanWaghetti I edited your answer, if you don't like please rollback, just some feedback. \$\endgroup\$ Mar 8, 2013 at 15:25
No, there is no formula to calculate charge time of a capacitor. Or yes, there is: \$t_C=\infty\$: the capacitor will never get 100% charged. What you can do is calculating the charge on a given moment, as shown here:
Specifically interesting is the formula for Q as shown in the graph:
$$Q=CV_b(1-e^{-\frac{t}{RC}})$$
We have \$C=0.001F\$, \$V_b=5000V\$ and \$R=20000\Omega\$. We can calculate our time constant, \$RC=R\cdot{}C=0.02s\$. Our formula now is:
$$Q=0.001\cdot5000\cdot(1-e^{-\frac{t}{0.02}})=5\cdot(1-e^{-\frac{t}{0.02}})$$
We can rewrite this so that t becomes a function of Q:
$$t\approx-0.02 log(0.2 (5\cdot-Q))$$
Now, just fill in the charge you want to reach and you'll get the time needed.
As rawbrawb mentions in the comments, we generally use as a rule of thumb that the capacitor is loaded after 5 to 6 time constants. So, in your case, that would be 0.1 to 0.12 seconds.
  • \$\begingroup\$ In a purely mathematical sense, yes charge time is \$ \infty \$ but the general rule of thumb is 5 to 6 time constants. Because in reality there are noise floors or even the precision of the system. \$\endgroup\$ Mar 8, 2013 at 15:13
If it is a normal PSU with a current limiter then your cap will charge linearly. Think of it as charging a cap with a current source.
$$Q = C\cdot{}U = 1\mu{}\textrm{F} \cdot{} 5000 \textrm{V} = 5\textrm{mC}$$ $$ t_{charge} = \frac{Q}{I_{lim}}$$ Assuming 250mA current limit (\$5\textrm{kV}/20\textrm{k}\Omega{}\$) your cap will charge in approximately 20ms.
  • \$\begingroup\$ 20ms is only true when there is only current limiting and no series resistance. \$\endgroup\$
    – jippie
    Mar 8, 2013 at 21:52
