What's the function of the timer's output buffer?
\$\begingroup\$ Lore Gala - Hi, (a) Stack Exchange rules are that anything written in the box labeled "Your Answer" below, as you did, must be an answer to the original question. Therefore your "answer", despite being a polite "thank you", has been deleted. (b) Please see here in the site help center about what to do when someone answers your question. I also recommend looking at the tour. Thanks. \$\endgroup\$– SamGibson ♦Dec 31, 2021 at 17:38
As internal signals are only strong enough to drive the internal circuitry connected to them, the buffer provides strong output current drive ability for driving external circuitry.
The function is the typical output used from the 555. It can sink or source up to 100 or 200mA to drive LEDs, perhaps a relay etc. See the datasheet
I googled and found these. That may help you.
The 555 timer IC can be used as an inverting buffer as well.
