I am looking to use an LDO with a negative adjustable output voltage. I have found two products sold by TI that have similar schemes for setting the output through external resistors.
I am slightly confused though, as one of the resistors in each scheme is illustrated as a potentiometer. Why is this so? Can a fixed value resistor be selected instead?
Also, the first regulator series (LM79XXAC) have fixed negative outputs but external circuitry can be configured to make it adjustable. For instance, take the -5-V fixed LDO in adjustable output configuration.
If this was instead the -12 V fixed output version, would the output equation change such that 12 V is substituted for 5 V in the above?
The external circuitry for the second LDO (LM337LM) is much the same as the other LDO series as shown below.
However, the output equation varies from that of the first LDO series, not including a current term. Is there a reason for this?
Finally, both datasheets do not seem to provide an input voltage range. Is there something I am missing? I need to figure out how to select a value of Vin for a given Vout.
Here are links to the Datasheets:
Thanks, everyone
