I am designing a simple digital circuit on a PCB that includes a power supply that provides +24V and -24V, but there is no ground. I am assuming that the negative voltage (-24V) is ground? What about the IC's that use a GND pin?
I plan on using a 2-layer board with the bottom layer as "ground", but what is "ground" in this case?
I have included the schematic. In the schematic is a +24V and -24V power supply that supplies the power to the DC/DC converter, and the converted voltage to the IC - but this IC uses GND, and I am not sure where GND is from? Or what the common is for the DC/DC converter?
