I am a bit confused with how voltages distribute themselves in the circuit, for the positive cycle the diodes D1, D2 are turned on.
We have positive input voltage terminal connected to D1's anode and there's a negative input voltage terminal connected to D2's cathode.
The load resistor is in between these two diodes for positive half of cycle.
If the negative terminal of input voltage is taken as 0 volt, which is connected to diode D2's cathode, and as per figure the anode of D2 is also connected to 0 volt of the negative load resistance terminal, then there would not be any voltage drop in diode D2 and it wouldn't conduct?
