I'm designing a simple PCB that will control some sensors/actuators with a microcontroller.
The microcontroller requires 3.3V and I'm planning to support different types of sensors/actuators that can require either 5V or 12V supplies, but all have 5V logic level.
3.3V: Easy, a step-down converter that accepts anywhere from 5V to 12V.
5V for the logic shifter: I could do the same as with 3.3V, but what if the power supply itself is 5v?
I've opened up a cheap LED strip controller I had laying around, one that supports any power brick from 5V to 24V. That controller has a buck converter for 3.3V and what seems to be an LDO (I can't read the part number,) bringing the 3.3V up to 5V for the logic shifter.
I could do the same, but that seems like a waste of energy so I was wondering if there is a better way to go about this.
    \$\begingroup\$ An LDO can't bring 3v3 back up to 5. Could a buck-boost work for your case? \$\endgroup\$
    – nanofarad
    Jan 5, 2022 at 17:08
  • \$\begingroup\$ Right, so what I thought to be an LDO, must be another buck converter. Interesting \$\endgroup\$
    – Cyborgium
    Jan 5, 2022 at 18:11
  • \$\begingroup\$ A buck converter also cannot bring a voltage up. A boost converter may, a charge pump may, but a buck converter by design bucks (lowers) a voltage. \$\endgroup\$
    – nanofarad
    Jan 5, 2022 at 18:12
5v for the logic shifter: I could do the same as with 3.3v, but what if the power supply itself is 5v? I was wondering if there is a better way to go about this.
I'd consider using a buck-boost converter. An example: -
If you need more than 1.5 amps, there are others to choose from. Other products made by TI will also do the job. The point I'm making is this: use a buck-boost regulator. ADI also provide this device for a 1 amp output: -
