Theory of operation: op amp detects higher-than-reference voltage and triggers SCR, which remains in low-impedance state until current drops close to zero (hopefully by blowing the fuse).
Main motivation: sharp and precise over-voltage protection of 3.3V electronics downstream of a surge-protected power supply.
R1/R2 form a voltage divider. R3 biases the voltage reference (which will be a shunt reference voltage IC instead of a zener diode as shown). R4 pulls SCR gate to ground when op amp output is floating (during power up).
Is anything missing? Am I overlooking anything?
Crowbar circuit
    \$\begingroup\$ Maybe use a comparator instead of an op-amp. Comparators are designed for switching, but op-amps are designed to be used in linear circuits. Also, maybe some feedback from output back to the +terminal of the comparator. I would be tempted to add a little something to keep the comparator VCC alive for a bit (for example a diode and capacitor) to make sure it stays on plenty long enough to fire the SCR. Once the SCR fires, the Vcc rail for the comparator is going to collapse. Maybe that is OK since it is an SCR. \$\endgroup\$
    – user57037
    Jan 10, 2022 at 4:20
    \$\begingroup\$ If you design it with an opamp, you could also use an NMOSFET as shunt. That way short transients will be resolved without blowing the fuse. \$\endgroup\$
    – tobalt
    Jan 10, 2022 at 4:40
  • \$\begingroup\$ What mkeith says keeping the opamp supply alive for a small while to ensure the SCR is fully enabled before drive is removed. \$\endgroup\$
    – ATCSVOL
    Jan 10, 2022 at 5:14
    \$\begingroup\$ 'hopefully' blowing the fuse. Make sure the PSU has the capability to do this reliably. We bought a very expensive instrument whose crowbar only succeeded in setting fire to the PSU becaue it wasn't quite beefy enough to blow the fuse. \$\endgroup\$
    – Neil_UK
    Jan 10, 2022 at 6:59
What's wrong with the fairly accurate TL431 type crowbar circuit. There are plenty of examples on google using SCRs and Triacs: -
Link to picture.
Link to picture.
Link to picture
I mean, why go for both a shunt regulator and an op-amp (comparator) when the TL431 combines both and is ideal for the job: -
There are literally dozens (if not hundreds) of examples to be found using this search engine term.
Reinventing the wheel is only useful if something new is brought to the party. Use something tried and tested is my advice.
    \$\begingroup\$ figure sources? esp fig 9.102? \$\endgroup\$
    – Neil_UK
    Jan 10, 2022 at 9:39
  • \$\begingroup\$ @Neil_UK it's one of the many pictures to be found in the google search link embedded in my answer. \$\endgroup\$
    Jan 10, 2022 at 9:42
    \$\begingroup\$ I wonder whether that's adequate according to the site rules, perhaps ask on meta. I've been asked to post actual links for each picture before, rather than just instructions on how to search for them. \$\endgroup\$
    – Neil_UK
    Jan 10, 2022 at 9:44
  • \$\begingroup\$ Maybe, maybe not. I shall add links. \$\endgroup\$
    Jan 10, 2022 at 9:45
