I've been gaining understanding about using relays to control PWM signal (ON/OFF).
Setup: Pixhawk generates PWM signals and sends it to motor controllers to control the 24V DC motor's speed.
Goal: To place a relay in between the Pixhawk and motor controllers to turn the spinning motors ON/OFF by controlling (turning ON/OFF) the PWM signal. Functioning of the Relay will be controlled using an Arduino. One relay for one motor.
What kind of relay is recommended to be used with this setup?
Any help will be appreciated. Thank you!
