6
Iam trying to simulate the loading behavior of an EEPROM. It is powered by a 5V LDO. When would the EEPROM actually consume power?
  1. Does it consume power during the entire read/write cycle time? As per my basic understanding, digital ICs only consume power during state transitions. If so, shouldn't we be considering the sum of all rise/fall time for power calculation within a write cycle.
  1. Why does this source refer to both rise time energy and write energy? enter image description here Disclaimer: Iam not a digital guy and know very little about the timing parameters.
    \$\begingroup\$ Everything consumes power when statically operated. It may not be much, but, it's always present. \$\endgroup\$
    Commented Jan 10, 2022 at 18:00
    \$\begingroup\$ Think about it... why does a write cycle take so long? \$\endgroup\$ Commented Jan 10, 2022 at 19:25
  • \$\begingroup\$ @BruceAbbott: It takes multiple clock cycles to complete a write operation (which might consists of many sub operations). Thats all I can infer from that \$\endgroup\$ Commented Jan 11, 2022 at 7:09
14
Here is an example write current waveform from the NXH5104 4 Mbit Serial SPI EEPROM datasheet.
In the table of 'Static characteristics' the average write supply current with 4 sectors active and 5 MHz SPI is specified as 1.1 mA at 1.2 V. In the trace we do see a continuous current draw of ~1.1 mA. However there are also large 4 large spikes not directly related to SPI bus activity. The total charge consumed during the write cycle is a combination of the continuous current plus these bursts (which presumably are caused by the actual erase/write operations).
  • \$\begingroup\$ Sorry I have no idea how to interpret the above diagram. 1. What does D4-D1 indicate? 2. Why are there periodic dips( momentary glitches) in D4, D3 waveform? \$\endgroup\$ Commented Jan 11, 2022 at 7:27
    \$\begingroup\$ The traces aren't well labeled. D4-D2 are the (digital) SPI clock and data lines. In this time frame each SPI transaction is so short that it looks like a glitch. If expanded you would see the individual clock pulses and data bits. It seems that the eeprom is being polled at intervals of a few hundred us, to detect when the write is finished. \$\endgroup\$ Commented Jan 11, 2022 at 9:45
7
  1. Yes, the EEPROM datasheet says that it consumes max 1mA while constantly reading from it, and max 3mA during a write cycle which can last up to 5ms, it does not even matter if you write a single byte or full page, as internally the EEPROM has to power the internal voltage generators for the full read-erase-program cycle.
  2. Digital signal transitions communicating with chip takes energy, and internal EEPROM erase-write cycle to store the data takes energy. Two completely different things.
This is wrong in general. CMOS logic gates consume most of their power during transitions on their inputs. A EEPROM IC:
  • may have components other than logic gates (e.g. charge pumps) which consume power differently
  • has leakage currents in idle state which may or may not be significant
  • may generate transitions internally (e.g. may have internal clock signals) without any changes on the IC pins
