Hi people -
I'd like to bounce this off some fellow engineers/gearheads...
I've built a turntable system to add to my Shapeoko 3-Axis CNC machine. The idea is to turn the machine into a CNC lathe of sorts, turned on its side. The motor for my turntable is a 100 RPM (max) brushed DC gearmotor, rated at 60W, and having a 12 - 13.5 VDC input. In that I need the speed to be variable, I have also purchased a speed controller. I intend to drive the system with a 12 Amp Linear 270W power supply with a regulated 13.8 Volt DC output. The seller from whom I bought both the motor and speed controller (MakerMotor.com) advised me to add a 12V battery (lead-acid is fine) in parallel with the power supply in order to protect the speed controller from current surges coming from the motor when slowing the system down. The speed controller is a MD25HV "25Amp 7V-58V High Voltage DC Motor Driver Speed Controller", per his website.
I can see the physics behind using the battery in this way, but what about instead putting a big diode in the + line so that current can only flow FROM the power supply TO the motor and not the other way around? It seems if it tried to do so it would "bounce" back & forth between the diode and the motor until it dissipated in the lines between them. It seems like a way to avoid needing the battery.
