I want to install a number of Mission Solar 420 W PV panels (pdf) on my roof. By estimating an average of 5 solar hours per day over the course of the year, I believe I need 9 kW of panels. So by a nominal calculation of 420 W x 22 panels = 9240 W
, or 9.24kW
However, that is only using the nominal wattage. How do I reduce that number based on roof angles and inverter efficiency to determine how many panels I actually need?
If my inverter is 95% efficient, then my usable power with 22 panels is reduced to 8778 W, so I need to add another panel to get back above 9000 W.
As for roof angles, do the average solar hours that people use for a quick calculation (5 hours) include a basic estimate of the inefficiency of standard roof angles and assume roof location can get decent coverage? Or do those calculations need to be done separately?
