I have this current sensor, it has a measuring range of 0-20A and outputs 0-1V.
I need to create a circuit that uses this current sensor, and trimming a current threshold (using a trimmer) the circuit will generate a pulse on output that will be used in order to detect if the load was switched on from my MCU (ATMEGA328P)
How i can do that?
What i've done so far?:
Actually i'm using this CT in this configuration and i detect when the load is switched on by sampling the analog values and determining the on/off with a software based threshold, but my intent is to keep this logic out of my software and get a pulse to my ATMEGA328P when the load is switched on/off.
circ
  • \$\begingroup\$ Just add an analog comparator ... with a digital output. NB : there is a comparator in the MCU. \$\endgroup\$
    – Antonio51
    Jan 14 at 16:33
    \$\begingroup\$ arduino.stackexchange.com/questions/23551/… \$\endgroup\$
    – Antonio51
    Jan 14 at 16:41
  • \$\begingroup\$ Thanks, but what is the threshold of the internal comparator? Also, the values that are coming out from the CT are floating +/- 1V...how the internal comparator will work? \$\endgroup\$
    – VirtApp
    Jan 14 at 21:54
  • \$\begingroup\$ The values coming out of the CT are centered on 2.5V, so no worries. If I remember well, the two inputs of the comparator are "accessibles", so one can wire the output of the CT on one input, and a chosen value (by a pot) on the other. See section 22 of the datasheet. <<<Overview ... The analog comparator compares the input values on the positive pin AIN0 and negative pin AIN1>>> \$\endgroup\$
    – Antonio51
    Jan 14 at 22:00
