-6
How can i connect 2 leads to 1 input lead and remotely control the 2 leads to be on or off so that the 1 lead can get a reading from either lead? The leads read electric and gas lines by milliamps. I have to connect 1 lead to a ground and 1 to the gas or electric service. Is there a way to connect both services at once and remotely control each service signal?
New contributor
Annaie243 is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • 6
    \$\begingroup\$ we have absolutely no idea what leads these are, what test equipment they connect to, what you want to control… \$\endgroup\$ Jan 14 at 17:30
    \$\begingroup\$ How about this? Is thus enough info? Sorry I wasn't very clear the first time. \$\endgroup\$
    – Annaie243
    Jan 14 at 17:49
  • \$\begingroup\$ not sure how a "lead" reads something; maybe a drawing of the whole current and wanted measurement setup helps. \$\endgroup\$ Jan 14 at 18:28
