I am using a CMOD S7 board to generate UDP frames and also an external PHY LAN8720 (RMII interface) to transmit them, which is connected to a Type C Ethernet adaptor in my PC.
A few details:
Connections: VCC, GND RMII_CLK (50MHz) from pmod of CMODS7 to nINT/RETCLK of LAN8720
similarly connected rmii_tx_en, rmii_tx_data0, and rmii_tx_data1.
When I connect them all and analyse the traffic with Wireshark I don't see any frames being transmitted by the LAN8720 to the PC.
Following are my parameters:
module UDP_send #(parameter dst_addr = 48'hFF_FF_FF_FF_FF_FF, // Destination MAC address (broadcast)
src_addr = 48'h00_12_34_56_78_90, // Source MAC address
dst_ip = {8'd10,8'd0,8'd0,8'd1}, // IP destination address (broadcast)
src_ip = {8'd192,8'd168,8'd0,8'd2}, //IP source address
dst_port = 16'd80, //Destination port src_port = 16'd80
Wireshark shows the following many times, the ARP packets:
Luxshare_90:1f:6e Broadcast ARP 42 Who has 10.0.0.1? (ARP Probe)
And this frame:
10.0.0.1 10.0.0.255 UDP 153 ✓ 49814 → 1534 Len=111
Could anyone help me find the issue or debug points so that I can proceed further?
