I am designing a carrier board for the RPi CM4 Lite (no eMMC) and having trouble understanding the documentation.
The CM4 proved a SD_PWR_ON and SD_VDD_override signal defined as:
The SD_PWR_ON signal is used to enable an external power switch to turn on power to the SDCARD, for eMMC it typically isn’t used. If booting from SDCARD is required then a pullup resistor must also be fitted to default the power to be on. When SD_VDD_override is high, this signal is used to force 1.8v signalling on the SDIO interface. Typically this is used with eMMC memory.
The example schematic in the datasheet and used on the CM4IO board reference design include a power switch (U18) controlled by SD_PWR. This appears to allow the Pi to power down the SDcard. However, we would never want to power-down the SDcard used to boot the Pi and are even instructed to pull this up if booting form SDcard. Is it necessary to implement the switch circuit, or can I simply power the SDcard directly from +3.3V? sdcard schematic
I would also like to understand how SD_VDD_override is used. The CM4IO board does not connect this pin to anything but the datasheet says it is used to force 1.8V signaling on the SDIO interface. Is this an input or an output? Perhaps you pull this high if you are connecting an external eMMC with 1.8V signaling to tell the Pi which voltage to use? I wish they provided a schematic for the CM4 itself to see how this is used with eMMC memory. Is there any situation in which an SDcard with 4-lane serial bus would need 1.8V power? It is my understanding that all SDcards work on 3.3V except UHS-II which need a different connector anyway.
I can confirm now that the SDcard works fine with Vdd supplied directly from 3.3V without any power switching logic. The SD_VDD_override and SD_PWR_ON pins to the CM4 module are left unconnected on my PCB and so far everything works expected.
The external SDcard can only be used with the CM4lite, and since it is the bootdisk there is no reason to support any card detection or hotswapping. It is still a mystery to me how those pins are intended to be used.
  • \$\begingroup\$ Thanks for the info. I was wondering the same thing. By the way, how come we don't need at 22 ohm series termination or pull-up resistors on any of the lines? When I design an SD Card interface circuit with SDIO, I usually put in those components to ensure robustness of the circuit. Are they not required here? \$\endgroup\$
    – Patratacus
    Aug 28, 2023 at 16:33
