I have a few on hand and I would like to control the output voltage with an arduino. Maybe with a digital potentiometer, but the datasheet calls for fairly strict wiring with short leads and little noise. Is there a better way to approach this? Should I use a different module and if so where should I look? Sorry if this isn't the correct way to ask I'm pretty new to this.
New contributor
Alex Schulz is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
    \$\begingroup\$ It'll degrade the step response of the supply but within reason it'll probably be ok. If you're worried, you can use an analog output pin on the Arduino and a resistor to generate current with relatively little parasitic capacitance. \$\endgroup\$ Jan 15 at 4:06
  • \$\begingroup\$ Most Arduinos do not have an analog output but they do have PWM which with a low pass filter can become analog voltage. The DUO has I believe 2 true analog outputs which are created with its interhan DAC. A digital pot should be fine. Normally you would not constantly be programming it which is the point it would probably generate the most noise. \$\endgroup\$
    – Gil
    Jan 15 at 19:55
Alex Schulz is a new contributor. Be nice, and check out our Code of Conduct.
