I'm trying to reverse engineer an amplifier, and there's two components that I cannot identify. For context, it was made in 1973 so it's all quite vintage.
I think the first one might be some kind of fuse? There's two on the board, one between Vcc and GND, and one between the output and GND via a 10 ohm resistor. It's marked with the text 82/250, 250V maybe, with some kind of rating?
Thing
The other component is some kind of blobby thing that might be a capacitor or a coil? But if it's cap, there should be some kind of value marking, so I would expect more bands or some text?
Blob
EDIT: some more blob pictures, one from the other side, one from the top:
Blob
Blob
    \$\begingroup\$ 82nF @ 250V mylar cap? The second item might be a PTC - thermistor. The Japanese were partial to using these. Most of that old stuff you can get schematics for on the web. \$\endgroup\$
    – Kartman
    Jan 15, 2022 at 11:22
    \$\begingroup\$ If the first component is connected between Vcc and ground, then it is certainly not a fuse : a fuse is basicaly a wire (or a very small resistor), so if yoy put a fuse between VCC and ground, you make a short circuit, so the fuse will blow imediatly. So there is no point of putting a fuse between VCC and ground, as it will be gone at once (excepted maybe as a strange way to detect if the device was ever used or not) \$\endgroup\$
    – Sandro
    Jan 15, 2022 at 11:26
    \$\begingroup\$ First one could be a polyphenylene cap. In that case it's most probably 82 picoFarad rather than a nano or micro farad. \$\endgroup\$ Jan 15, 2022 at 12:19
  • \$\begingroup\$ Oh wow bit of a derp moment on the fuse. So yeah let's go for a cap :') much better idea. \$\endgroup\$
    – Michel
    Jan 15, 2022 at 12:26
  • \$\begingroup\$ Can you get a photo of the second one from the opposite side? \$\endgroup\$
    – winny
    Jan 15, 2022 at 12:28
Second items looks to be a (Philips) Vishay PTC thermistor like this one but not necessarily this value: https://uk.farnell.com/vishay/ptccl13h321hbe/thermistor-ptc-8r4-20-radial/dp/1187084
  • \$\begingroup\$ I added more pictures, in particular look at the one from the top. Seems like it's way too thick for a PTC thermistor? Usually those are relatively thin? \$\endgroup\$
    – Michel
    Jan 15, 2022 at 12:57
