I'm looking for current sens resistors. As those are rather big (and beeing for now the limiting element for my PCB size), I would like to stop using over-rated one and take some with "just" the power rating needed.
So I was wondering what exactly the powerrating means?
If for exemple I choose a 0.5W resistor. Does that mean that it is meant to be used at 0.5W, or that it might get destroyed at 0.500001W?
And how about power dissipation (the datasheets I looked at have no information about it) : can I do my layout as "bad" as I want and have the 0.5W rating, or do I need to have a layout optimized for heat dissipation if I want to get the ratings from the datasheet?
If you want a more specific use case, there is the one I'm currently working on :
- using the resistors for measuring motor current (usualy for now 0.1A nominal, worst case 1A for about 1 minute (motor stalling), driver has internal *5 voltage amplifier for sens resistor voltage)
- resistors in the range 0.2-0.3 ohms
- I started my design with 0.2 ohms, 3W, 2512 package (wanting some margin to switch to bigger motors if needed, the driver can handle 2.5A, so 0.2*2.5^2=1.25W, so 3W seemed safe). Now I realized that the resistors are too big to fit, so I'd rather loose the possibility to get bigger motor than increase the size of the PCB. -I would like to go down to 2010 package or smaller (nb : I mainly care about length, so for exemple 1812 is also perfectly fine)
- one of the resistors I was think to use now is this one : 0.5W, 0.24 ohms, 1812 package
- air temperature will be 30°C max (while testing at home), 14°C max in real use (it's for a caving robot)
