I think what you are getting at is that you may not need to know transistor-level design since you can just use integrated circuits (such as an op-amp).
Op-amps are analog components, so designing a circuit with an op-amp would be considered analog design.
You can use an op-amp without knowing how it works at the transistor level. But sometimes knowing how it works may allow you to use it more effectively or have a better intuitive understanding about what problems you may see or how to mitigate them.
You can possibly be a good driver without knowing much about how a car works. But if you don't know how cars work, you may have trouble fixing them, for example. I suspect that most professional drivers (truck drivers, race car drivers, etc) know a little bit about how cars work.
Also, there is a possibility that your career will take an unexpected turn and you may need to use a simple transistor-level analog circuit for some reason (cost, for example).
I don't want to read too much into your question. Maybe you are an EE student frustrated because you don't like transistor level analog design or something like that. That's fine. I didn't like control theory much in university.
But if your basic attitude is that you don't want to learn any more than the bare necessity, and that learning about how things work is a chore (rather than a pleasure) there is a possibility that engineering is not a good career for you. Again, it is understandable that there will always be gaps in a person's knowledge, and also, some areas of engineering may be more interesting to you than others. That is all fine and good.
