Since the operating point of the circuit is determined by analysing it in DC, the capacitors behave as open circuits.
At this point, as far as I understand it, the voltage at node V+ is determined by the voltage divider consisting of resistors R2 and R1.
$$V_+ = E \frac{R_1}{R_1 + R_2} = 30\text{ mV}$$
Since the operational amplifier is ideal, due to the virtual short-circuit principle, node V- will have the same voltage.
The voltage drop at the ends of resistor R4 causes a current to flow towards ground. The same current will flow through R5, since it cannot pass through the input of the op amp.
This way I can determine
$$V_x = R_5\frac{V_-}{R_4} + V_-=0,3V$$
But at this point either I find a negative Vout or the diode remains off and Vout = 0.
What am I doing wrong?
