I was wondering if it's possible to find the admittance parameters of a pi two-port network experimentally using an LCR meter.
For the network shown below, we have $$ \begin{bmatrix} I1\\ I2 \end{bmatrix} = \begin{bmatrix} Y1 + Y2 & -Y1\\ -Y1 & Y1 + Y3 \end{bmatrix} \begin{bmatrix} V1\\ V2 \end{bmatrix} $$ So, if we short-circuit \$Y3\$ (\$V2 = 0\$), and connect LCR meter between nodes a and c, we measure admittance \$Y1+Y2\$, i.e. element \$y_{11}\$. Similarly, if we short-circuit \$Y2\$ (\$V1 = 0\$), and connect LCR meter between nodes b and c, we measure admittance \$Y1+Y3\$, i.e. element \$y_{22}\$.
However, I don't see how can we get \$Y1\$ since \$Y1 = \displaystyle-\frac{I2}{V1}\$(when \$V2 = 0\$), and I don't have access to measure either current or voltage but only impedance/admittance using the LCR meter.
Does anyone know if that's possible? If so, how do we proceed? Also, can a network analyzer help with this task? Maybe through the use of S-parameters?
P.S: I'm working with a low frequency (100 Hz - 10 kHz).
