I got a custom PCB. I am using DRV8428P driver (here is the datasheet) for a stepper motor. The problem I am facing is not being able to have the stepper rotate faster than 5 rpm. Also, the stepper makes a very loud noise.
Here is the schematic of my stepper controller:
Here are the specs of the stepper motor:
Here is how I wired up my stepper to the custom PCB:
My controller is Raspberry Pi Zero and I am using Python to drive the stepper:
import RPi.GPIO as GPIO
import time
delay = 0.0005 #time to settle
AIN1 = 21 # GPIO21
AIN2 = 26 # GPIO26
BIN1 = 20 # GPIO20
BIN2 = 8  # GPIO8
def setup():
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(AIN1, GPIO.OUT, initial=GPIO.LOW)
    GPIO.setup(AIN2, GPIO.OUT, initial=GPIO.LOW)
    GPIO.setup(BIN1, GPIO.OUT, initial=GPIO.LOW)
    GPIO.setup(BIN2, GPIO.OUT, initial=GPIO.LOW)
setup()
def setStep(w1, w2, w3, w4):
  GPIO.output(AIN1, w1)
  GPIO.output(AIN2, w2)
  GPIO.output(BIN1, w3)
  GPIO.output(BIN2, w4)
  time.sleep(delay)
try:
    while 1:
        setStep(1,0,1,0)
        setStep(0,1,1,0)
        setStep(0,1,0,1)
        setStep(1,0,0,1)
except KeyboardInterrupt:
    pass
GPIO.cleanup()
When I decrease the delay value, the stepper mostly won't move but vibrates. The delay value that seems to work is 0.0005. However, the stepper makes a loud noise and barely rotates. I uploaded a short video of the stepper here: https://streamable.com/6kyayx.
I am not sure how get the stepper to spin as fast as 150 rpm as it is stated in the stepper's specs. I also have a hard time translating the hints to Python code, which are given in the steppers specs regarding high torque and initial phase setup.
Any ideas?
  • \$\begingroup\$ Is this really a 5V motor, attempting to drive with 24V? \$\endgroup\$
    – rdtsc
    Jan 19 at 13:21
  • \$\begingroup\$ DVDD is 5v (measured it myself). \$\endgroup\$
    – mr-ma
    Jan 19 at 13:50
Check with a multimeter that red-yellow is one coil and blue-orange is the other.
The chart shows that you've got to start the stepper at about 500 Hz and ramp up. Starting at too high a frequency will cause it to stall.
500 Hz would correspond to 2 ms per step rather than 0.5 ms which is what your delay = 0.0005 is giving you.
  • \$\begingroup\$ how did you convert 500 Hz to 2 ms delay in this case? Can you please share the formula? \$\endgroup\$
    – mr-ma
    Jan 19 at 12:40
  • \$\begingroup\$ @mr-ma, I imagine the formula was: freq period = 1/freq. You'll find that on about page 1 of many electronics books and you should take the time to learn such electronics basics if you hope to get your circuit working successfully. \$\endgroup\$
    – TonyM
    Jan 19 at 12:45
  • \$\begingroup\$ @mr-ma. Thanks for accepting my answer. Was 2 ms the solution? As TonyM pointed out, \$ t = \frac 1 f \$ where \$t\$ is the periodic time and \$f\$ is the frequency. (Hertz means cycles per second, after all.) \$\endgroup\$
    – Transistor
    Jan 19 at 18:39
  • \$\begingroup\$ Does it work now? What was the solution? \$\endgroup\$ Jan 25 at 0:48
