I'm working on a hobby project based on the ATmega32U4. I'd like to be able to power the device by USB or LiPo battery. I was looking at the schematic for the LilyPad ProtoSnap Plus and saw a diode that looks like it's intended to prevent the battery from powering the load during charging.
As I understand, charge managers without power-path support may never "finish charging" a battery if the load is high enough to draw power from the charge manager/battery. Some more expensive and more complicated ICs have this built in, but not the LilyPad.
Instead, they have a Schottky diode between the battery output and USB power. It seems like as long as the power consumed by the load is adequately supplied by the USB power rail the charge manager won't be tapped as a power source, but I don't really know that to be true.
TL/DR Is the Schottky diode (D1) enough to support a power-path that doesn't prevent the battery from being "fully charged" when the load is present during charging?
