I tried to simulate this oscillator in Multisim, but it doesn't work, I get just DC voltage from it. With the same biasing I got to make it work, but on lower frequency (around 1 MHz), while I want to get it around 100 MHz from it. Do you have any idea why does it not work? I know results from simulators are often different from real life, but I don't want to order the components, and try it out at home if I know that my design is junk. enter image description here
Edit: I tried using my new design, and it doesn't work again. Input impedance is high, inductance is much higher than capacitance, it's biased as an A class Common Collector amplifier, and transistor should now support so high frequencies. What is wrong with my design?
Edit 2: enter image description here
I decreased emitter's impedance, but it still won't work.
Edit3: enter image description here
My transient settings.
Edit4: enter image description here
Transient response of my design, which is seen in edit4. enter image description here
Transient response of Andy aka's design.
  • 12
    \$\begingroup\$ How does the gain of a 2N2222 compare at 1MHz vs 100MHz? \$\endgroup\$
    – brhans
    Commented Jan 19, 2022 at 18:35
    \$\begingroup\$ I don’t think a 2N2222 is designed for such high frequency operation. This datasheet onsemi.com/pdf/datasheet/p2n2222a-d.pdf indicates rise and fall times in the 10 to 100ns range for switching applications; your circuit is a linear one but I’d expect that a few MHz will be all you can get. \$\endgroup\$
    – Frog
    Commented Jan 19, 2022 at 18:37
  • \$\begingroup\$ It says transition frequency around 300MHz. That's why I have chosen this transistor. \$\endgroup\$ Commented Jan 19, 2022 at 18:39
    \$\begingroup\$ C1 and C2 are much to large - it may work with capacitors of 10-20pF with the inductor much larger. In practical circuits C3 would also be much smaller - maybe 1000pF. It may not matter for a simulation depending upon what the parasitics are. \$\endgroup\$ Commented Jan 19, 2022 at 18:43
    \$\begingroup\$ @Pavle, I've edited your question title so that readers will understand what your question is about. "Why does this circuit not work?" doesn't give many clues for someone finding it in search engine results. \$\endgroup\$
    – Transistor
    Commented Jan 19, 2022 at 18:44
4 Answers 4
9
I think this is a common misunderstanding of the "transition frequency" characteristic of transistors / opamps. A transition frequency of 300 MHz doesn't mean the transistor "works" up to 300 MHz. It means above 300 MHz it will be completely useless (gain < 1, no matter what operation mode you use).
Practical schematics expect transistors to have gain >> 1 (among other things), so unless your design accounts for severe parameter degradation which happens as you approach the transition frequency, you should target a frequency which is at least an order of magnitude (i.e. 10 times) smaller than the transition frequency, and in high gain applications using parts at 1/100 of their transition frequency is common.
    \$\begingroup\$ I up voted this in 5 seconds, btw have I met you in a Rasberry pi question? \$\endgroup\$ Commented Jan 20, 2022 at 7:21
    \$\begingroup\$ @VScode_fanboy Thanks, it's indeed possible you saw me on RPi SE, I post there a lot. I see you have not asked/answered any questions there, at least with this account, and unfortunately I don't remember over which question we could have met though. \$\endgroup\$ Commented Jan 20, 2022 at 7:25
Why does this transistor oscillator not work at 100 MHz?
In one of your previous questions, I proposed this 100 MHz oscillator circuit: -
As you can see, L1 is about ten times what you are using and C1 and C2 are also much smaller than what you propose in your circuit. You also need to use a transistor that has got a decent β into the GHz, possibly a BFR90 to get results that are close to the formulas.
In my simulation above, I got 100.6 MHz but that was with a BC547. Theoretically it should be around 140 MHz (from memory) and, to achieve this you'll need a much better transistor or, live with the discrepancy between reality and formula.
  • \$\begingroup\$ What is the reason that I can't choose higher cap and lower L value? I thought it's all about resonance, but there must be something else. \$\endgroup\$ Commented Jan 19, 2022 at 18:55
    \$\begingroup\$ It's not strictly speaking about resonance but about phase shift. Resistors (the biasing resistors) also play a role here and they lower the Q of the circuit making the transistor work a bit harder thus offsetting the real frequency from the theoretical frequency. Low values of inductance also means a low Q factor so, you choose L to be a lot higher (I guess experience also matters a lot). \$\endgroup\$
    Commented Jan 19, 2022 at 19:00
  • 4
    \$\begingroup\$ @PavleHribar - oscillators in simulation often require kicking at startup. You may be able to modify the startup conditions of the simulator or intentionally provide a pulse to start oscillation. In the real world oscillation will start from noise that may not be present in the simulation. \$\endgroup\$ Commented Jan 19, 2022 at 19:36
    \$\begingroup\$ My sim (micro-cap) has the option to start right from a cold start i.e. "disable start from operating point" - if your result doesn't show the proper start up of the waveform (as per my middle picture) then you need to locate the "switch" that forces a cold start. If you don't have the operating point start disabled, it tries to find the natural dc conditions after everything has settled down then applies those before starting the circuit transient response and, that does (or can) cause problems. \$\endgroup\$
    Commented Jan 19, 2022 at 20:51
    \$\begingroup\$ It won't work as you thought because of the increased impedance presented by the emitter on such a lower collector current. We want the emitter to be low impedance (but not zero ohms) because it has to drive the capacitors and inductor. We are in the realms of compromise here; a simple transistor oscillator is an imperfect thing; you have to balance several things together to get a performance that is close to the theory especially at frequencies above circa 20 ish MHz. \$\endgroup\$
    Commented Jan 19, 2022 at 23:37
  1. You've chosen a transistor that doesn't have much gain at \$100\mathrm{MHz}\$, and
  2. Your tank circuit's characteristic impedance is much, much too low.
I don't have data for a 2N2222 handy, but the data sheet I have on hand for a 2N3904 lists an \$f_T\$ of \$250\mathrm{MHz}\$. You can make a transistor oscillate at or below its \$f_T\$, but things get difficult, and the quality of the oscillator is low.
A typical rule of thumb is to use an \$f_T\$ that's 10 times higher than your design frequency. This will mean that your board layout won't be trivial (\$1\mathrm{GHz}\$ -- eek!), but certainly for simulation it should work*. You can probably shade that down a bit. So, find a transistor with \$f_T \ge 500\mathrm{MHz}\$.
An oscillator oscillates because you put a signal into it, it goes around the loop, and it comes out at exactly the same phase and amplitude. To make something oscillate, you need a loop gain that's significantly higher than 1 at zero phase shift. There's a lot of ways you can achieve this -- for a bog-standard Colpitts oscillator, with a small-signal transistor, that means that at your design frequency, your capacitors should have an \$X_C \simeq 100\Omega\$, and your coil should have an \$X_L \simeq 200\Omega\$. Your \$250\mathrm{pF}\$ caps have \$X_C \simeq 6.5\Omega\$ -- that's simply not going to work**.
So -- change your transistor, both caps, and your coil, and you'll have something that ought to simulate OK. Then when you're ready to lay it out check back here because you're almost guaranteed to get it wrong.
* For the 1980's-era RF design I'm used to - with through-hole components and TO-92 cased transistors - \$100\mathrm{MHz}\$ is getting to the upper limit of frequencies to contemplate without going to "microwave" methods. With all surface-mount parts and a tight layout you can probably use a "traditional" Colpitts oscillator - but you may need to go with a more "microwave-ish" circuit, where you have to treat every circuit trace like a resonator. Getting your hands onto some recent amateur radio designs is probably a very good idea.
** Maybe for some super high-power application, where you're using an RF output transistor that's biased to have gain into such a low-impedance load. But not with a small-signal transistor.
  • \$\begingroup\$ Note that the circuit that @Andyaka showed you in his answer is pretty close to what I was recommending (I haven't done the actual math for the impedances, but it should be close). \$\endgroup\$
    – TimWescott
    Commented Jan 19, 2022 at 23:21
My recollection of a "free standing" oscillator is that it has positive feedback in the circuit and it depends on the amplification of component noise to start oscillating. The real world noise and startup conditions are not easily duplicated in a simulator model so one might need to apply tips and tricks to simulate the oscillator.
This reference describes the startup problem, as quoted below, and the article has many more specific tips and tricks that may or may not relate to the answer to your specific question:
https://docs.easyeda.com/en/Simulation/Chapter9-Initial-conditions-and-starting-up-circuits/index.html
Even if the circuit is an oscillator, prior to t=0 it will have been assumed to be in a stable non-oscillating steady state. At t=0 the circuit will then start from those initial DC conditions. It will then either continue in that steady non-oscillating state or will slowly drift away from the steady DC state and oscillations will build up.
The initial state of oscillators based on a tuned circuit such as phase shift, Wien Bridge and Crystal Oscillators will be defined by their DC bias conditions. If there are no noise sources in the circuit (the default state for all components unless otherwise specified such as resistors defined to have noise contributions) then there is nothing to nudge the circuit away from equilibrium and so it may never start oscillating.
Although in most cases such oscillators will eventually start up due to the ‘hidden’ noise source which is simply due to the mathematical noise generated by the finite resolution and rounding errors of the calculations carried out in running a simulation, this can take a very long time compared to the time taken to run the oscillator in a stable oscillatory state for a few cycles. Crystal oscillators in particular can take many hundreds of thousands of times the oscillator period to start up and reach a stable state.
To minimise the simulation time spent waiting for an oscillator to start, it is useful to introduce some initial start-up condition to ‘kick-start’ the circuit into oscillation.
Note that a typical microcontroller enables the circuit designer to specify a startup delay which helps ensure a stable oscillator signal prior to program execution after power-on, brown-out, or reset condition.
