I have a project that i need to send some data with an RS232 to USB cable from external Msp430 launchpad to the computer and fake it as a mouse. Is this possible without learning USB protocols of the mouse?
You could pretend to be a Microsoft Serial Mouse: http://paulbourke.net/dataformats/serialmouse/
Edit: if that doesn't work, and the computer has a PS/2 mouse port, you can use that: http://www.computer-engineering.org/ps2protocol/
Otherwise you're going to have to get a microcontroller with USB support and learn that, which will be time-consuming.
  • \$\begingroup\$ Does that still work with newer OSes? I remember I tried using some serial mice with Vista and 7 and they didn't work, but I didn't try to figure out if they died or the OS didn't support them. \$\endgroup\$ – AndrejaKo Mar 11 '13 at 10:09
  • \$\begingroup\$ Hmm - it's not clear, although I can see a couple of questions on stackexchange about "how do I prevent my serial device being wrongly detected as a mouse on Win7?". \$\endgroup\$ – pjc50 Mar 11 '13 at 10:18
  • \$\begingroup\$ This is basically the answer. I'd just point out that a USB HID implementation may not be all that complicated if you find a microcontroller eval board with an HID mouse demo. Some of these will cost less than a logic-level USB-serial cable. \$\endgroup\$ – Chris Stratton Mar 11 '13 at 12:40
Microchip has a PICDEM Full Speed USB Demo Board for this. This demo board comes with a program that emmulates a HID mouse using USB. You could adapt this program to create your fake mouse.
