I am moving from LTspice to NgSpice. In the former the inductance has a default value of a series resistance of 1milli oHms (that could be set to zero by adding 'Rser=0' in the line command defining the value and nodes of the inductor), whereas for the latter no information seems to be given in the documentation. Does anyone have an idea if the NgSpice inductors have a series resistance or not. If yes, what is the command to use in order to set its value to 0?
Thanks in advance
