I'm experiencing an interesting issue with Eagle's polygon copper pour. As you can see below, the solid red is the copper pour area, while the dashed line is showing the complete polygon outline (I clicked on it to show it). I don't know if you can see, but the pour (the solid) actually has a bend to it that is somewhat noticible. It's not straight as it should be. This is the first time I've seen this. There isn't anything on any other layer that I know could be causing this. Does anyone know what could be causing this? Is this a bug in the software? I'm using Eagle 6.3.0.
[Edit] Interestingly enough, moving the outline specified by dimensions more to the left does remove the issue, although it makes the board larger.
