I was reading about a capacitive soil moisture sensor circuit today, and came across the following diagram:
(Diagram taken from the Cave Pearl Project, https://thecavepearlproject.org/2020/10/27/hacking-a-capacitive-soil-moisture-sensor-for-frequency-output/)
As the peak detector section of this circuit uses the filtered output of a 555 timer, which I believe should never be a negative voltage, what is the purpose of diode T4? Is it really necessary in this circuit?
Any insight would be much appreciated!
