I have a set top box. It has a 3 mm green LED (on the front panel) that lights up when I connect the dish coax cable (signal LED).
I measured the voltage across the LED. It has 0 V when the dish cable is disconnected and about 1.2 V (max) when I connect the dish cable.
I would like to add a buzzer to this LED. It should buzz when the green signal LED comes on.
I have a few of those tiny buzzers from old Pentium 4 PC motherboards. I connected one across the LED but I only managed to get a low humming sound (I guess it lacks a signal generator? 555 positive triggering?).
I want to use the voltage from the LED as a trigger (555 IC) and an external 5-12 V power supply to induce a loud 1200 Hz signal in the buzzer. I have a square wave generator which showed that the buzzer was at its loudest at 1.2 kHz.
Any help with a schematic would be greatly appreciated.
Added later:
Here pin 2 of 555 timer ic is the trigger. How do I trigger this circuit using the 1v coming from the led diode?
