I have written the following code for sinc3 flter in verilog (Vivado). I need to ask how shall I now convert this RTL design to a logic Gate level design in verilog (add AND, NOR, flip flops, etc.)? Would appreciate any suggestions.
`timescale 1ns / 1ps
module dec256sinc24b
(input mclk1, /* used to clk filter */
input reset, /* used to reset filter */
input mdata1, /* input data to be filtered */
output reg [15:0] DATA, /* filtered output*/
output reg data_en,
input [15:0] dec_rate
/* Data is read on negative clk edge */
reg [36:0] ip_data1;
reg [36:0] acc1;
reg [36:0] acc2;
reg [36:0] acc3;
reg [36:0] acc3_d2;
reg [36:0] diff1;
reg [36:0] diff2;
reg [36:0] diff3;
reg [36:0] diff1_d;
reg [36:0] diff2_d;
reg [15:0] word_count;
reg word_clk;
reg enable;
/*Perform the Sinc action*/
always @ (mdata1)
if(mdata1==0)
    ip_data1 <= 37'd0;
    /* change 0 to a -1 for twos complement */
else
    ip_data1 <= 37'd1;
/*Accumulator (Integrator)
Perform the accumulation (IIR) at the speed of the modulator.
Z = one sample delay MCLKOUT = modulators conversion bit rate */
always @ (negedge mclk1, posedge reset)
begin
    if (reset)
    begin
    /* initialize acc registers on reset*/
        acc1 <= 37'd0;
        acc2 <= 37'd0;
        acc3 <= 37'd0;
    end
    else
    begin
    /*perform accumulation process */
        acc1 <= acc1 + ip_data1;
        acc2 <= acc2 + acc1;
        acc3 <= acc3 + acc2;
    end
end
/*decimation stage (MCLKOUT/WORD_CLK) */
begin
    if (reset)
        word_count <= 16'd0;
    else
    begin
        if ( word_count == dec_rate - 1 )
        else
            word_count <= word_count + 16'b1;
    end
end
always @ ( negedge mclk1, posedge reset )
begin
if ( reset )
    word_clk <= 1'b0;
else
begin
    if ( word_count == dec_rate/2 - 1 )
        word_clk <= 1'b1;
    else if ( word_count == dec_rate - 1 )
        word_clk <= 1'b0;
    end
end
/*Differentiator (including decimation stage)
Perform the differentiation stage (FIR) at a lower speed.
Z = one sample delay WORD_CLK = output word rate */
always @ (negedge word_clk, posedge reset)
begin
    if(reset)
    begin
        acc3_d2 <= 37'd0;
        diff1_d <= 37'd0;
        diff2_d <= 37'd0;
        diff1 <= 37'd0;
        diff2 <= 37'd0;
        diff3 <= 37'd0;
    end
    else
    begin
        diff1 <= acc3 - acc3_d2;
        diff2 <= diff1 - diff1_d;
        diff3 <= diff2 - diff2_d;
        acc3_d2 <= acc3;
        diff1_d <= diff1;
        diff2_d <= diff2;
    end
end
/* Clock the Sinc output into an output register
always @ (negedge word_clk )
begin
    case ( dec_rate )
        16'd32:begin
            DATA <= (diff3[15:0] == 16'h8000) ? 16'hFFFF : {diff3[14:0], 1'b0};
        end
        16'd64:begin
            DATA <= (diff3[18:2] == 17'h10000) ? 16'hFFFF : diff3[17:2];
        end
        16'd128:begin
            DATA <= (diff3[21:5] == 17'h10000) ? 16'hFFFF : diff3[20:5];
        end
        16'd256:begin
            DATA <= (diff3[24:8] == 17'h10000) ? 16'hFFFF : diff3[23:8];
        end
        16'd512:begin
            DATA <= (diff3[27:11] == 17'h10000) ? 16'hFFFF : diff3[26:11];
        end
        16'd1024:begin
            DATA <= (diff3[30:14] == 17'h10000) ? 16'hFFFF : diff3[29:14];
        end
        16'd2048:begin
            DATA <= (diff3[33:17] == 17'h10000) ? 16'hFFFF : diff3[32:17];
        end
        16'd4096:begin
        DATA <= (diff3[36:20] == 17'h10000) ? 16'hFFFF : diff3[35:20];
        end
        default:begin
        end
    endcase
end
/* Synchronize Data Output*/
always@ (negedge mclk1, posedge reset )
begin
    if ( reset )
    begin
        data_en <= 1'b0;
        enable <= 1'b1;
    end
    else
    begin
        if ( (word_count == dec_rate/2 - 1) && enable )
        begin
            data_en <= 1'b1;
            enable <= 1'b0;
        end
        else if ( (word_count == dec_rate - 1)  && ~enable )
        begin
            data_en <= 1'b0;
            enable <= 1'b1;
        end
        else
            data_en <= 1'b0;
    end
end
endmodule
  • \$\begingroup\$ Similar question on SO \$\endgroup\$
    – toolic
    Jan 25, 2022 at 15:22
  • \$\begingroup\$ 1st choose a Synthesis Tool \$\endgroup\$ Jan 25, 2022 at 15:24
  • \$\begingroup\$ Synthesise it... \$\endgroup\$
    – user16324
    Jan 25, 2022 at 15:33
    \$\begingroup\$ I’m voting to close this question because it's an exact duplicate of a question on another site. \$\endgroup\$
    – user16324
    Jan 25, 2022 at 15:34
  • \$\begingroup\$ @user_1818839 Yes, I synthesis it in Vivado, but it generates the desing in. RTL in (LUTs, mux, etc) but i want the desing to be in logic gates (AND, NOR, etc.) \$\endgroup\$ Jan 25, 2022 at 15:41
Vivado synthesizes RTL into Xilinx primitives (LUTs), not gates.
If your objective is to target a standard cell library restricted to gates and flops you need a synthesis flow (like Synopsys DC /VCS) that does that.
  • \$\begingroup\$ Since this is a paid software. Is it possible to get it for free? \$\endgroup\$ Jan 26, 2022 at 1:20
