I'm trying to use a WS2812B addressable LED with a multiplexer 74LVC1G157. The WS2812B uses NZR protocol comunication at 800 Kbps and each pixel scan frequency not less than 400 Hz.
I have test code on an Arduino, and all works fine, but when I use two different LED signals, one from an Arduino and one from a Raspberry using the Neopixel library, it sometimes works fine, other times, the LED goes crazy, always with the Raspberry signal.
I have tested all, the signal from the Raspberry is fine if I test it with an LED without the multiplexer. If I touch the multiplexor connectors, the behaviour changes (sometimes fine, sometimes wrong).
I attached an image with the adapter I'm using (where I think the problem comes from):
