I've made an attempt at this question, but the answer was wrong. Could someone please tell me where I was wrong in my calculation?
  • \$\begingroup\$ The error might be rounding 14.8 to 15, so the answer should be 14. \$\endgroup\$
    – Klas-Kenny
    Jan 27, 2022 at 7:21
  • \$\begingroup\$ should i not round up to cover every step? \$\endgroup\$ Jan 27, 2022 at 7:27
    \$\begingroup\$ Your values are all correct. For an ideal ADC the transfer function, the value is rounded down (if your LSB is 0.5V, 0V=0, 0.1V=0, 0.2V=0, 0.3V=0, 0.4V=0, 0.5V=1), and input of or is offset by half a bit (0V=0, 0.1V=0, 0.2V=0, 0.3V=1, 0.4V=1, 0.5=1). The question must be assuming that the transfer function is not shifted over. Bad question IMO. embedded.com/… \$\endgroup\$ Jan 27, 2022 at 7:30
  • \$\begingroup\$ NB: if voltage reference is 2.56 V and ADC (not shifted) is 4 bits -> voltage resolution is (typo error) 2.56/16=0.16 V. So, the voltage for 1111 is 15*0.16= 2.4 V. \$\endgroup\$
    – Antonio51
    Jan 27, 2022 at 11:04
So please provide the correct answer.
In my opinion, when you got 14.82 you cannot change it to 15 which is the nearest; you are to decide the lowest natural number which is 14.
    \$\begingroup\$ It depends on which ADC transfer function is used. embedded.com/… \$\endgroup\$ Jan 27, 2022 at 7:31
  • \$\begingroup\$ I think you're using 'Answer' on this Q&A site like 'Reply' is used on discussion sites. Although well-intended, this is a comment as it just requests more information then presents an opinion, not a definite Answer. I appreciate that you don't yet have sufficient Reputation points to have posted this as a comment. \$\endgroup\$
    – TonyM
    Jan 27, 2022 at 8:39
The voltage resolution is wrong — 4 bits gives \$2^k\$ steps = 16, not \$2^k-1\$ (that would be the highest code, 0b1111 = 15).
The binary value sounds correct though, regardless of whether the transfer function is offset by 1/2 LSB or not.
