I'm a little bit confused here.
I assumed that the transmission is going to be PCM, so I calculated this way:
I assumed number of bits (n) and sampling frequency (64.4 * 2) then I said that the minimum data rate is n*sampling frequency.
Is this right or is the minimum data rate the same as the sampling frequency?
