It's just a simple multiple of Pd= 12V x 0.3A x 80 pc. .
But the hard part is the PTC positive temperature coefficient for tungsten bulb resistance means that power drops to this level only when they are hot. When cold it is about 11 or 12 times this power level but only for the 1st cycle of AC.
This means 80 tungsten bulbs are a real big problem for DC power supplies because they will trip with overcurrent protection on startup unless you sequence them on and have excess capacity.
Coincidentally it is not much different to driving a 288 Watt motor as DC motors also have a surge power and current rating of 10x the full load rated power (+/-20%).
A far better solution is to use LEDs.
There is an alternative but it requires some electronics with a 30 Amp choke and low ESR cap with a 50 A FET switch in PWM. This is more of a challenge.
Anecdotal
Back in the late '70's, a music-award-winning composer-for-film friend I grew up with, http://peterallenassociates.com/site/ was in a rock group called RAINTREE and he wanted me to make exactly the same thing in "Fat Albert Lamps." So I made each letter a 15A Triac Controlled 120Vac channel with 8 channels. Then I went further and made it into a "Chaser" with bi-directional scanning and speed control. That was just a weekend project and I still had time, so I add phase control with a zero-crossing switch using a CMOS XOR gate offline then an electret mic input for the drums so the rhythm of the drums would sequence the lights. That worked famously with tape over the mic because it was too sensitive. But I heard years later it failed when the console technician put on 1kW flood lamps on each channel and turned the sequence speed up too fast allowing the lamps to cool down enough so they drew 20 to 40 Amps per channel and blew out all the Triacs. So even the Technician did not know about PTC effects. But then "Black Pete" moved from Winterpeg to Vancouver and the rest is history with over 185 film scores with famous actors and directors for Sillywood.
