First of all I'm a hobbyist so please assume I know very little.
I have a broken battery-based drill and I'm transforming it to be wall mounted, without batteries.
The motor has a label saying RS 550S-14.4V. I tried to supply it from a 12 V, 3 A wall-mounted transformer and it worked, but the transformer was not mine, so I bought another.
I bought a 14 V, 2600 mA wall-mounted transformer and it cannot stay on. If you press the trigger too fast the drill stops.
I thought it was too much consumption in peaks and that the cheap Chinese transformer could not handle it, so I got an ATX power supply. According to the label it can provide 19 A at 12 V, which should be PLENTY. I fooled the PSU to start (PS_ON - GND, Pwr_OK - 5 V) and it started.
But then the same happens: if I press too hard or too fast, the power supply cuts itself off. The PSU fan stops, so I know the problem is the PSU and not in the drill mechanism.
What am I missing here? I cannot provide anything more powerful than the ATX's 19 A.
