I am designing a floating point unit in verilog. I have designed separate adder, shifter and multiplier modules in verilog. I want to call all these modules and make a single main module. I am not able to instantiate these modules inside always block, but I also need clock in my main module. How do I overcome this problem?
You can't instantiate modules in always block. Do it before and assign a clock to that module.
  • \$\begingroup\$ i dint understand clearly. \$\endgroup\$
    – twinkle
    Mar 12, 2013 at 8:11
    \$\begingroup\$ add Your source code snippet to pastebin. \$\endgroup\$
    – Tomas D.
    Mar 12, 2013 at 8:24
  • \$\begingroup\$ @Socrates please consider expanding your answer with some explanatory text suitable to the expertise level demonstrated in the question. \$\endgroup\$ Mar 12, 2013 at 9:42
  • \$\begingroup\$ i have only the codes of my submodule. Did u mean that i should instantiate the modules first and then give clock in a seperate always block? will it serve the purpose of having a clock in my main module? \$\endgroup\$
    – twinkle
    Mar 12, 2013 at 11:10
    \$\begingroup\$ You need to learn how to instantiate modules in top module first of all. Each module should have clock input, so just assign clock to that input. You don't have "to clock the module" somehow. The module itself is like a small design, that You have to provide clock to. I don't know how to give any better answer, when the OP doesn't know the basics of language he/she is designing. \$\endgroup\$
    – Tomas D.
    Mar 12, 2013 at 11:31
