The goal is to control various Peltier modules using an H bridge and a PWM signal.
I've designed this schematic and made a PCB out of it.
It is an H-bridge using 4 IRLR7843TRPBF high power MOSFETs and 2 2ED21091S06FXUMA1 half bridge MOSFET drivers.
I have followed the data sheet of the MOSFET driver and everything seems ok, yet when I supply the circuit it shorts itself through the MOSFETs and I don't understand why.(I know that is through the MOSFETS because I checked it with a thermal camera)
In fact, the gate logic should prevent a short no matter what. Page 6 of the gate driver IC.
So far I have changed the 10k gate resistors to 22 ohm ones and nothing. There is no physical short nor bad soldering. I'm running out of idea Is there something wrong with the schematic?
I'm starting to think that some components might be damaged.
EDIT: The schematic is right. The Source and Drain pin numbering in the schematic did not match the pin layout of the real componente, in fact what happend is that Source and Drain were inverted.
2ED21091S06F :datasheet
