I was wondering if an industrial-grade inductive sensor can detect an anodized aluminum plate. From what I know, based on the working principle of these sensors (basically the metal is detected by its own magnetic field thanks to Eddy current) I suppose the sensor would have a hard time detecting the anodized surface, but I'm not sure.
Kindly let me know based on your experience or knowledge regarding the topic. Thanks in advance!
P.D.: In case you ask about the specific type of anodizing, for this case let us consider a simple Type-II anodizing, with a thickness no greater than 0.4 mils.
The thin layer of anodization will not really affect the performance of the inductive sensor in any way.
No more than air, paint or any other non-conductive material between the sensor and the metal. The sensor will not detect the anodization in itself, but it will still detect the aluminium that is behind it.
  • \$\begingroup\$ Thanks for the explanation! I will implement a couple of inductive sensor on my application :) \$\endgroup\$ Jan 31 at 21:10
