- I am adding the figure of a conventional setup for electrostatic induction.
- The drawn setup on paper is the special setup.
- If you don't want to read whole description then just read the summary.
Conventional:
Special:
We know the conventional way of charging by electrostatic induction, by placing the conductor sphere-1 (I am using sphere so we can distinguishing identity of this conductor in question) near the charged object and connecting the conductor to Earth and then finally removing the Earth connection and then removing the charged object, so by this we get a charged conductor (sphere-1.)
The new setup is the as same as above except this time I am not connecting the conductor (sphere-1) to Earth, rather I am connecting a wire from conductor (sphere-1) to another conductor (sphere-2.) Sphere-2 is not under the influence of the charged object, and keeping all the other things same.
- Will charging by electrostatic induction occur in this special setup?
- Will sphere-1 have some charge after removing the charged object and the connection from sphere-2?
Summary
In the conventional setup for electrostatic induction, if we change the setup a little bit by removing the Earth connection and instead of that we connect it to another conductor (which is not under influence of charged object,) then will charging by electrostatic induction occur here? Will sphere-1 have some charge after removing the charged object and the connection from sphere-2??
